Piece longer than my cnc.
I would like to carve a piece of wood 3 meters long but, my cnc is 1 meter long. How can I split the toolpath to carve the piece in 3 times to make the entire 3 meters?
George-Roberts
I would create some workplanes and use the Split command to split your part. Then create a setup on each of the new parts which should give you the toolpaths you need (Post them out separately)
If you have never used the split command, let me know I can put together a short video showing how I would approach this
Edit: Please find below a sample video below 🙂 (modelled a random thing up as an example, should show the principles though)
Steinwerks
Another option instead of splitting the part you can use the 3D toolpaths and draw confinement sketches to use as boundaries that match your work envelope.
The two sketches seen in the image allow for confinement in a 4th-axis setup to maintain rigidity but the principle is the same. If you pattern the sketch with a point to select for a WCS you can keep your coordinate system and move the part a set distance two times after the initial setup.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Thank you very much for your answer, it works very well.
