I'm sure there is an easy way to do this but it's still confusing. Here is what I'm trying to do.
I have a single part and a known size piece of stock. .5" X .75" X 5". I would like to machine 5 of the same part out of this single piece of aluminum, make soft jaws then flip the stock and machine the back side.
My problem is how do I make copies of the part, and move them inside of the stock that Fusion defines? I would think this is a simple CAM operation where I could duplicate the part, move it in the X- axis and be done. I do know about defining stock from a solid model, but I should be able to define stock in CAM and just add more instances, right? Or does Fusion not work that way? Do I have to do all the setup in the Model environment?
