looking for a post edit - Okuma M560-5AX
- Mute
- Permalink
- Report
I pulled this post off the forum and made just a few changes that I could, but there are a couple that I cannot do myself if anyone wants to check it out...
Looking for the "PH" value in the CALL 0088 line to match the work offset. Currently it just spits out an PH=1, no matter what work offset I specify, forcing me to only use G15 H1.
Also, I would like the tool to move to the initial cutting position BEFORE the 4th and 5th axis are rotated (Tool call and start, CALL 0088, initial position, THEN rotate axis, THEN Z move). Currently, a tool is called, the axis are rotated, THEN the CALL 0088 is called and the tool moves to the initial cutting position.
Thanks in advance!
Link copied
