How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
I have drilled and tapped hundreds of holes in things modeled in Fusion
I don't know if I'm just over tired, but I can not get the Drill Cycle to recognize a tapped hole.
I can not select the threaded hole by selecting the face nor by using diameter range. I have no issues selecting non-threaded holes
If I go to the Design Workspace and suppress the threads, I can drill the pilot hole, but can not get a tapping toolpath to generate once I Un-suppress the threads.
I have never had this issue previously- did something just change?
I have a paid subscription, but do not pay for the hole recognition extension.
Thank you
You don't need the hole recognition wizard to do this. Can you share your Fusion file?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Thanks for the reply. I was always able to do this before with no issue
I have up loaded my model
Thanks for the help
It appears that the edge you selected to align your Z in the WCS is NOT a good edge. Rather, select the face of the part:
Result:
How to buy
Type a product name
