Issue recognizing holes
I have drilled and tapped hundreds of holes in things modeled in Fusion
I don't know if I'm just over tired, but I can not get the Drill Cycle to recognize a tapped hole.
I can not select the threaded hole by selecting the face nor by using diameter range. I have no issues selecting non-threaded holes
If I go to the Design Workspace and suppress the threads, I can drill the pilot hole, but can not get a tapping toolpath to generate once I Un-suppress the threads.
I have never had this issue previously- did something just change?
I have a paid subscription, but do not pay for the hole recognition extension.
Thank you
seth.madore
You don't need the hole recognition wizard to do this. Can you share your Fusion file?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Seth Madore
Thanks for the reply. I was always able to do this before with no issue
I have up loaded my model
Thanks for the help
seth.madore
It appears that the edge you selected to align your Z in the WCS is NOT a good edge. Rather, select the face of the part:
Result:
Seth Madore
Thank you very much. That fixed it. I would have never found that!
