How to mill connect pockets with different Depths?
jda70az
jda70az
Hi.
I can't figure out how to mill out 2 pockets that are connected but have different depths. I tried
both 2 d and 3d pocket strategies.  It either crashes Fusion or  hangs there with 0% processed
or Pending or... it leaves material at the edges.
File included.
Would someone here please explain what I am doing wrong?
Replies (11)
daniel_lyall
It makes it easy to help if we can see where you are going wrong, as I can get a toolpath with no problem.
See if this helps See this video for selecting toolpaths https://www.youtube.com/watch?v=ATs4rsI_TPc
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
jda70az
I select 2d pocket and select all 3 pockets in the Geometry TAB 3 chains
Set the bottom Height to the deepest pocket
turn off stock to leave
and that's it.
daniel_lyall
You do not need to touch the hights and this is the fail, reset it back to selected contours.
Daniel Lyall
The Big Boss
Mach3 User
jda70az
ok
Ok so
I select 2d pocket  and in the geometry tab I select all connected pockets
and hit ok. It either crashes, sits at 0% or says Pending and does nothing.
And yes I did what you said.
So my question is HOW do you properly mill a feature like this?
What would be the best  set of operations in what sequence?
Thanks for the help.
daniel_lyall
Can you post the model with the tool paths done? I need to see it to have a chance of working out what is wrong.
What are your computer specks?
Daniel Lyall
The Big Boss
Mach3 User
jda70az
Yup
Win 10
Intel Core i5-6600K 8M Skylake Quad-Core 3.5 GHz
EVGA GeForce GTX 1070 FTW
https://www.evga.com/products/specs/gpu.aspx?pn=262a811f-d3e9-4e51-af12-f808ec0a3b56
16Gig of DDR4 Ram
GA-Z170X Gaming MOBO 7
https://www.gigabyte.com/Motherboard/GA-Z170X-Gaming-7-rev-10#ov
etfrench
Is there a reason you chose the deepest pockets to machine first?  Try using the top profile as the selection.
ETFrench
jda70az
Yes
When I would select the bottom of the pocket it would sit at 0% and not create the tool path
or it would say Pending or crash Fusion. Which is really weird. I don't know why it was doing that.
I looked at your file and I see you selected the TOP line so that the pocket is all blue
I was selecting the bottom and that is the problem.
I will mark this as ACCEPT SOLUTION
etfrench
It did the same for me, so I changed the inputs and that worked.
ETFrench
daniel_lyall
@jda70az Did you looked at the video I posted in it it had how to edit the toolpath so it went where you wanted it to go?
Daniel Lyall
The Big Boss
Mach3 User
jda70az
Yes I did watch it and that was helpful.
marked as ACCEPT SOLUTION
