hi i trying to see how to get better time that match real machine time for quoting jobs i machine
example for a roughing time on fusion give me 1hr 7 mins but machine time 1h 37mins
i using the cv5 500 machine model from fusion i have done both way update the machine model feed and speed that machine can do and left it as it was but the time doesn't change on fusion am i missing something ? any help be great
sam
Solved by seth.madore. Go to Solution.
The most accurate place (in my experience) to fine tune the Machine Time is in the right click menu:
For my Mori, I've got it set to a 78 percent feed scale and that typically puts me within a few minutes on one hour cycles
that great thanks mine was 68 feed 36000mm for rapid and got it to be same as the machine time to match the machining tell me thanks again
