How do you put multiple objects on the same Z axis plane?
Hi, I have 13 objects with different Z axis heights inside my fusion 360 model, they are wooden inserts.
I want to move all 13 to sit on the same Z axis plane so I can manufacture the inserts out of a single piece of wood.
Is there an easy to do this I'm missing?
Thanks.
engineguy
@Anonymous
Please upload your Fusion file, go to "File > Export and then save as an f3d file to your PC and then attach it to your next reply.
I can't it's a commercial model I'll make something to illustrate the problem and upload that.
seth.madore
There's really not an "easy" way. First thing that comes to mind is just moving them all to the same plane. You can create copies of the components themselves, and move those instead, so you have the originals in the correct place.
Seth Madore
