I would like to edit the generic linuxcnc post processor of my mill in order to to make it work for the setting of a new 4th axis i will have soon, but I can't find it and save it as personal post pro. The folder autodesk/cam/post is empty.
How can I do it please?
thanks.
Solved by Steinwerks. Go to Solution.
Doing a search on this site, what I found is this:
/Users/UserName/Library/Application Support/Autodesk/Autodesk Fusion 360/XVU3R5GTE27D/CAMPosts
This "should" get you to the generic post files.
To edit them, you can open them up in Brackets if you'd like, or download a JavaScript editor. Notepad++ works great for PC, although I don't think they support Mac.
DO NOT save the file back to the generic folder. Put it in your Personal Posts section, which can be found here:
/Users/<user id>/Autodesk/Fusion 360 CAM/Posts
I don't have a Mac, so this is all second hand info
Thanks Kudos,
but I don't have that path on my mac , I have made a search for ".cps" extension and it even doesn't find anything.
thanks again anyway.
Patrick
If you specifically want one to edit then I'd suggest going here and searching for LinuxCNC: http://cam.autodesk.com/posts/
Once downloaded and edited, make sure you save it to your Cloud Posts and NOT the generic posts directory (if you've found it by then, that is).
I don't have a Mac either so not much use in finding that directory.
Thanks Kudos for quick reply again. If it can help, I’ve found another solution. I’ve installed fusion 360 on a virtual windows machine on my mac (like parallel desktop), connected to my account, as it is possible to edit the postpro under windows, I’ve edited it, made no changes," saved it as" on my OS X desk and than copy it to my personal post processor folder on the mac to edit. Ouf done. But your solution is simpler of course.
I hope the possibility to edit the post processors will be reactivated in the futures updates for mac users.
Thanks again Patrick.
