Hi.
We have a Haas TM-1P. The max feed rate is 400ipm, so this is the value I put into the Max feedrate field in the Machine Definition>Capabilities>Motion setting.
We recently changed to use the latest HAAS (pre-NGC) post haas.cps 44121, because it now incorporates many of the edits we'd made to our own fork of 38310 over time and has new cool capabilities. We'd like to stay on the Fusion-maintained post if possible.
After posting a bunch of jobs, we found they won't run because the F500 is too fast for our machine (agreed, I should have noticed before sending them to the shop). I'm now editing all the saved posts to set the Post properties>(Built-in) High feedrate to 400, but we need to be sure to check that every time we post. Alternately, we could modify the 44121 with highFeedrate = (unit == IN) ? 400 : 5000;, but then we have a fork that won't get updated.
It would be great if the Fusion Post-masters could check the machine capabilities and limit the highFeedrate if necessary.
CC
Is this the only Haas mill in the shop, or the only one that is limited in feedrate?
I can reproduce what you're seeing and have reached out to the Machine Config team to better understand this behavior..
