Fusion Manufacture
Bore function bottoming out on limits
2 REPLIES 2
surenotattoos
124 Views, 2 Replies
Hi, im new to fusion and CnC's I have created a file and used the bore function to cut 6.1mm holes at what I thought the depth of the stock would be but when I load it up on the cic it just plunges the bit until the CNC kicks out a warning saying limit reached and stops moving, I can't tell how much past depth its going but my guess would be almost double as almost the whole bit disappears. Any ideas?
TIA
2 REPLIES 2
We'd need your code and machine. My guess is you dont have Z limit switches and there's a G28 in your code. Is that close?
Please click "Accept Solution" if what I wrote solved your issue!
Im really sorry, the problem was me, I put the stock point on the surface rather then the bottom of the stock.
Technology Administrators
