Help with large chamfer?
- Mute
- Permalink
- Report
Hi, I'm having trouble machining a chamfer larger than the tool. I can create a toolpath no problem. The simulation in Fusion is perfect, but the resulting part has lines between each pass. I am using a 2D Contour and increasing the "chamfer tip offset" until I reach the bottom edge. Here is my file: https://a360.co/2FlCUT0
I've tried various different changes with no luck.
I've tried 4 different tools: a 1/4 carbide 2 flute, 3/8 carbide 2 flute, brand new 3/8 carbide 4 flute, and 5/8 HSS 2 flute.
I've tried ordering the operations from top to bottom and bottom to top.
I've tried changing the tip diameter of the tool in Fusion.
I've tried changing how much each pass overlaps each other.
I'm not sure what else I can try. Hopefully I'm missing something easy. I've ordered a larger chamfer mill that can do it in one pass, but I'd still like to solve this if anyone has any suggestions.
