Fusion Manufacture
Help Needed To Machine This Slot In A 20mm Thick Piece Of Aluminium.
7 REPLIES 7
Message 1 of 8
225 Views, 7 Replies
Hello Gents
I need some advice, as to which machining process to use, to machine this slot in a block of aluminium. I thought of using the "BORE" machining process, to machine the pockets for a shaft, which fits into the part? Now the slot, seems to be a bit of a challenge, because the SLOT machining process, normally machines in a straight or curved pattern. When I select the 3D ADAPTIVE process and select only the slot, it develops a tool path for the complete finished part.
Any advice would be appreciated as to what process(s) I should take? Like drill the 4 holes first, then machine the bore, then the slot and finally the outside profile.
I`ll try to attach the file.
Regards
Craig
7 REPLIES 7
Message 2 of 8
seth.madore
The main problem you're faced with is that this is an STL file. Natively, only the 3D toolpaths are going to play nicely. We can convert the STL to a BRep body, which would make it somewhat easier. However, considering the simplicity of this part, you'd really just be better off designing it from scratch. Do you have a print and dimensions to go off of? There really isn't more than 10-15 minutes of design time here.
Seth Madore
Message 3 of 8
in reply to: seth.madore
Hello Seth
Thank you for your reply.
I bought this file package, so that I can build a 4th and 5th axis, for my router.
These are the following download formats, which were supplied:
parasolid
sldprt
step
stl
I downloaded all of the stl files and if I use the measurement tool, I can see what the dimensions are.
Regards
Craig
Message 4 of 8
seth.madore
Oh jeez, if STEP or SLDPRT is an option, grab those instead, all the work is done for you.
Seth Madore
Message 5 of 8
Hi Seth
I understand.
The person who I purchased the drawings from, said that the parts are easy to machine. I placed the order yesterday, for all of the 20 mm thick aluminium plates. So its just the machining to do.
I have not tried to open a sldprt or step file in Fusion 360. I`ll give it a try.
Thank you for your assistance.
Regards
Craig
Message 6 of 8
seth.madore
Hi Craig,
Oh yes, the parts should be quite easy to machine, depending on what you have for equipment and tooling at your disposal. Where the challenge comes in with the STL files is that none of the easy-to-use toolpaths in Fusion (all the 2D paths) recognize the geometry created in an STL model. STEP and SLDPRT is king in this area, as it's recognized as true circles and lines
Seth Madore
Message 7 of 8
Hi Seth
You know, when I selected the slot and used the adaptive clearing process, the process selected the whole part. Meaning the slot, 4 bolt holes and the shaft bores. I thought this was strange? But now I know why? It was a stl file, which was opened, meaning 3D machining. I thought Fusion 360 was going crazy here?
My router is quite robust in construction and has a 2.2 kW spindle on it. I use compressed air to cool the carbide coated 2-flute end mills and am achieving satisfactory results. Just wished that I has built this earlier, as compared to the GT2 belt driven machine.
Regards
Craig
Message 8 of 8
seth.madore
Nope, Fusion wasn't going crazy. You can constrain it to certain areas with sketches. But honestly, finishing this part is going to be so much easier with an actual solid model, which the stl is not.
Regarding machining aluminum with just air; be careful. Even just a little bit of drip lubrication or mist will greatly reduce the chance of aluminum welding itself to the tool. It's doable with just air, just presents a higher chance of tool failure.
Seth Madore
Technology Administrators
