Would love to see support for this or the equivalent in Fusion
After the drill or reamer retracts, coolant on (spray not TSC) and spin backwards.
https://www.haascnc.com/service/codes-settings.type=gcode.machine=mill.value=G81.html
You can do this as a passthough note to add this to the code manually.
I could code the program without Fusion as well. But the point of buying a CAM software package is to not need to do that. It is a simple request to include support for this concept in a future release.
I assume you want to add an 'E' value to your G81 (and others?). This is possible to do in the post processor. Do you want it to happen on every G81 or is there some criteria?
