I get an image of a previous operation with a different design when I set up a new design in manufacture. Please see screen shot and tell me how to get rid of. thank you, JR
Solved by seth.madore. Go to Solution.
The few times this has cropped up, the only solution has been to close all files and restart Fusion.
Seth, this might be CAM-26519. A fix for this has been recently submitted. It will be available to users in an upcoming release.
The bug in CAM-26519 was that if you regenerate a toolpath in one document, then change to a different document before the toolpath generation finishes, the toolpath from the first document would be displayed in the second document. Is that possibly what has happened here?
Ahh, good call. I never connected a set of actions with this result, but it does track with the times I've seen this behavior..
thank you fellas. I have definitely changed to other design as operation is generating. One issue is my machine is not up to snuff with video card. JR
