@TurtleRacing
Dovetail is tricky, the values you are using won`t produce a 1.5mm tool, to get a tool that size without any Radii you would have to have a Flute length value of 0.866in, now if you add a corner rad of 0.02in you will need a Flute length value of 0.846in but you will then only have a tool diameter 1.471in.
When you put all the values in and get to the last box which is the angle when you highlight it the 30 degrees should be 30 degrees, not 30.00001 degrees, if it is the latter then Fusion is saying that it has calculated the angle from all the previous values so if you just try to change the diameter without changing any of the other values to match then it will revert to the size that it has the correct values for 🙂 🙂 🙂
What I do with Dovetails that I don`t have the specs for is to do a sketch that will get me all the values I need to correctly create the Dovetail Tool, image of an example sketch below and example file attached, if any of the above made any sense to the reader then as they say "my work here is done" 🙂 🙂 🙂
I think what folks are expecting is to be able to just change a tool diameter and Fusion will automatically change all the values to match, now that would be nice 🙂
It is prefectly logical I suppose and once I got the hang of doing it that way it is pretty easy to get it right without having the correct tool specs !!!!!!
Of course having gone through all of the above ramblings by far the easiest way is to just get the tool specification from the tool Manufacturer/Tool Supplier and input the data, that is a minutes worth of work 🙂 🙂 🙂
Apologies, forgot to mention, all done with the New Tool Library !
Stay Safe
Regards
Rob
