Hi @koch.reto
below my answers to your questions.
Q
What's the reason why an additive method won't work with that post or that same principles?
Is it because of the extruder comand for material extrusion?
A
The 2 posts we have created are exclusive for subtractive toolpaths for now.
Subtractive and additive toolpaths have different types internally, as they are meant for different machines, we have limited the post for now to subtractive.
Would you want to use additive or FFF additive ?
When we have a additive robot post we will share this with everyone.
We have driven this hardware and built a few parts using other ADSK CAM software that also drives robots.
Q
How do you prepare the code for the robot with the Ambit extruder on it?
A
The code requires ON/OFF commands at move type changes, so we control on/off of the end effector at the correct location. Any additive process requires a few variables for process control, this that we need to implement. test and validate.
Q
Or does that KUKA Robot uses a KUKA CNC as a processor of G-code?
A
On our hardware we have used , KUKA CNC, KUKA KRL and KUKA CAMRob.
All depends on the complexity of the application/process and file size.
For clarity:
KUKA KRL is default robot language/syntax on a kuka, it is what we call robot native language.
KUKA CNC is cost option add-on software that allows you to drive the machine using GCode syntax/file
also used to overcome memory limitation common on large files such as on milling. It has a few more tricks in the bag, for more info ask KUKA directly or KUKA integrator
KUKA CAMRob is another cost option add-on software that allows for overcoming memory limitation and process control, for more info get in touch with KUKA Belgium.
Does this answer your questions ?
If not let me know.
Alex
Alexandre Pinto
Process Specialist
