Frezowanie w osi C na tokarce - C-axis milling on a lathe
xeywp21edsadasd
Community Visitor
Community Visitor
xeywp21edsadasd
Community Visitor
Community Visitor
Witam, mam problem z wyfrezowaniem (łezki) na tokarce. Chciałbym to zrobić w osi x/c z użyciem napędzanego  narzędzia. Czy mógłby mnie ktoś nakierować, jak to zrobić?
Z GÓRY DZIĘKUJĘ ZA POMOC
[translated with Google]
Hello, I have a problem with milling (teardrop) on a lathe. I would like to do it in the x/c axis using a driven tool. Could someone direct me on how to do it?
THANK YOU IN ADVANCE FOR YOUR HELP
a.laasW8M6T
Hi
See attached file
Whether the Code is output as XC will depend on your post processor
Can you tell us which Machine you have and What post processor you are using?
xeywp21edsadasd
Community Visitor
Community Visitor
Maszyna to tokarka HAAS ST15Y i postprocesor dedykowany ze strony autodesk.
Próbowałem na innych postprocesorach i na żadnym nie wychodzi. Na podesłanym pliku frezowanie jest osiowe, tak tez mi wychodziło, natomiast ja chcę to frezować promieniowo (od boku) ponieważ detal docelowo ma 100mm długości (model jest poglądowy) i nie mam tak długiego freza żeby zrobić to osiowo Myślę, że błąd mam gdzieś w modelu (doborze operacji, orientacji narzędzia)
The machine is a HAAS ST15Y lathe and a dedicated postprocessor from the Autodesk website. I have tried other postprocessors and none of them work. The file you sent is axial milling, which is how it worked for me, but I want to mill it radially (from the side) because the final part is 100mm long (the model is illustrative) and I don't have a cutter long enough to do it axially. I think the error is somewhere in the model (selection of operations, tool orientation)
Ahh sorry
I didn't realize you wanted to mill using a Radial tool.
I will Create a File that shows how to do this when I get a chance later today, You will need the Manufacturing Extension to use the 4 axis toolpaths though.
Do you just want to use XC or  can you use the Y axis too? Does the machine have a Y axis?
a.laasW8M6T
Hi See video and attached file
xeywp21edsadasd
Community Visitor
Community Visitor
Dziękuję bardzo za odpowiedź. Mam możliwość użycia osi Y. Przepraszam, że nie wysłałem od razu docelowego modelu. Znajduje się on teraz w załączniku. Teoretycznie potrzebuję osi X,C i Y, w osi Z dojadę już ręcznie. Czy uda mi się wygenerować ścieżkę bez rozszerzenia na 4 osie?
Przeanalizuję dokładnie Twój film jak wrócę z pracy.
