TFW when toolpath generation takes 10 times longer after tightening the surface triangulation tolerance and it still comes out like this:
And then Fusion crashes when trying to simulate...
Please, prioritize bug fixes. FFS.
Oh, that's gorgeous. 😬
Can you share the part?
enable the blend toolpath in preferences under preview features, it takes a little longer to calculate, but it works much better than flow and scallop
The answer is not to use an other operation.
I think its better to know why the toolpath is like we see in the picture
Also changing any small detail (such as changing cutter diameter by 0.01mm or the number of steps) completely changes the entry, often coming through the side of the part.....
