Fusion Manufacture
Corona Radius
4 REPLIES 4
Fueler
381 Views, 4 Replies
Corona Radius
I don't use them often but when I do a radius operation tasks me. sigh
I have tried different masks and social distancing. Nothing works.
I have some screen shots and the file to look at for help.
The first shot is the tool I am using.
The second shot is the simulation where everything looks and works as it should
The third shot is one I fiddled with to show what is happening at the mill.
The 4th shot is the tool cutter setting window which sits over the library window.
Notice the summary in the library window to the right.
I assume I have been screwing something up but when I see the difference between the cutter window and the summary window I begin to wonder if something is amiss in the software.
Any help appreciated.
4 REPLIES 4
Fueler
in reply to: Fueler
Did I stump the band?
kamil.malec94
in reply to: Fueler
Looks like whatever diameter you input, it then deducts 2x CR (0.015) to get the tip diameter.
Try putting .110 at your "Diameter" column, then the software will calculate that your tip should be 0.080 given specified corner radius. It is definitely misleading, because the software asks for "Diameter", but actually pointing to the tip diameter.
Fueler
in reply to: kamil.malec94
Interesting.
I will set up in a couple of days and see how that works out.
Dave
in reply to: Fueler
I have been using form mills in fusion alot lately. I actually draw the tool in fusion, then output a print and send to the tooling shop. No matter hat tool or shape, I always have to offset it in the machine by alot. I just did an op with a tool exactly like the one you are using and to get it to match the software, i have -0.022 in TL comp and +.015 in radial. Form tools never match on the machine to what I program them to in fusion. we even CMM'ed the tools to make sure they were correct.
Technology Administrators
