Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Flat toolpath not ramping
4 REPLIES 4
elijrobson
306 Views, 4 Replies
elijrobson
The Flat toolpath isn't ramping, I've checked the box, unchecked and rechecked with helix, profile and zigzag. It just plunges. I'm using a 2.5inch surfacing bit with replacable inserts and, hence the centre 40mm has no teeth so plunging is not at all suitable. I've selected a specific surface to machine as well as just limiting the top height to try and see if it fixes the problem but no luck.
Labels (4)
4 REPLIES 4
seth.madore
in reply to: elijrobson
seth.madore
Hmm, interesting. I'll try to look at this some more tomorrow.
That said, if you're machining this part from solid (based on your description), I would not be using the Flat toolpath, but favoring the 2D Pocket toolpath instead.
Seth Madore
Seth Madore
a.laasW8M6T
a.laasW8M6T
Hi
If you reduce the Lead-in Vertical radius to less than the Ramp Clearance height it appears to work correctly
Hi
elijrobson
in reply to: a.laasW8M6T
elijrobson
Ah, well that's a good enough work around. Must be an order of operations on the programming side?
Thanks for the solution!
elijrobson
in reply to: seth.madore
elijrobson
-seth.madore
I tend to need about 100 of these pockets of various sizes per sheet and so its a matter of me being lazy and not wanting to click 100 pockets every time. 😅
-seth.madore
