Facing stock in 4th axis with fusion 360- how?
darrenJ264A
Observer Observer
darrenJ264A
Observer
Observer
Programming this part in fusion360 with 4th axis and I can't figure out how to qualify the end faces programmable using the 4th axis. I was thinking of using the side of an end mill and spin the 4th axis but can't seem to figure it out
I have attached a picture to show what I am trying to do. I've watched videos and searched the internet and tried a bunch of different things and can't get it to work.
programming2C78B
following, but my guess is a Multi Axis contour. I don't have any example parts in front of me to try to make it work. It sounds easy enough to also program by hand, plunge along y0 and command a A360. move.
Please click "Accept Solution" if what I wrote solved your issue!
darrenJ264A
Observer
Observer
Thanks for the reply, That's sort of what I was thinking but figured I'd see if there was a way to program it
a.laasW8M6T
You can program this in Fusion with the Rotary contour toolpath fairly easily, i've done it several time for facing tubes to length
Andrew Laas
Senior Machinist, Scott Automation
darrenJ264A
Observer
Observer
That is it! Thanks for pointing me in the correct direction. That looks like it is going to work
