Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Facing a counterbore with boring bar starting ID traversing outwards X+
5 REPLIES 5
paul.slaterMZZFE
326 Views, 5 Replies
Hi could someone tell me how i can control the direction of the finishing cut-path below please?
At the moment it rapids in near to X0 then moves out to the start point, feeds on to the part and then feed in towards the centre. The tool is an 80 deg Rhomboid, which this direction is totally unsuitable for, it needs to feed out from the id towards the OD.
Thanks Paul
Labels (1)
5 REPLIES 5
@paul.slaterMZZFE
Assuming this is a turning toolpath, try setting the direction to "back to front".
Akash Kamoolkar
Akash Kamoolkar
Software Development Manager
Hi, thank you. Unfortunately I have already tried this and just tried again to make sure, it errors out with empty tool path.
regards Paul.
@paul.slaterMZZFE
Could you attach your file here so I could take a look?
Akash Kamoolkar
Akash Kamoolkar
Akash -please see attached as requested.
Regards Paul.
It's because you don't have "Allow Radial and Axial Grooving" turned on.
Seth Madore
