as you can see on the image is that i want to extend my contour because i want to mill the corner in the next setup, and also skip the holes. i tried to extend it with "to boundary" with no succes. is there a option to extend or skip it or will i have to use another milling feature.
Solved by weber_dominic. Go to Solution.
Solved by Camtech-CezayirYasa. Go to Solution.
Hi, you can limit the border you want by sketching in the Design section.
first off all, thanks for the reply 🙂 i tried the first option you gave me but it said that it has no passes to link...
Select the two blue lines seperately, then in the 2nd tab adjust their start/end tangential extensions until they mill into the vertex of the corner.
