I'm doing engraving with live milling tool and I'm having issues with the output of my POST which puts G54 M80 at the end of the cycle which puts Q-SETTER SWING ARM DOWN. It should finish the cycle and just go to home position. I have to manually get rid of those lines and was wondering is there a way to remove it without editing the post.
G code with the Q-SETTER SWING ARM DOWN
G0 G28 U0.
G28 W0.
M35
G28 H0.
M34
G54 M80
M30
Edited G code without Q-SETTER SWING ARM DOWN. Preferred.
G0G28U0.W0.
G28H0.
M30
Solved by seth.madore. Go to Solution.
At line 4816 (of the stock post), put a // in front of this line:
The "//" will cause that block to be ignored, thus preventing the code from being output
