Impressive Youtube video by Kevin Ellingson from Mechanical Advantage showing 3D Flat but
can't find in Fusion 360 or under Preview. Is it available on September 5, 2021 to everyone ...?
If so where is it?
thanks
mark
Solved by Marco.Takx. Go to Solution.
Solved by daniel_lyall. Go to Solution.
Do you have version number 2.0.10806
It should be under manufacture-milling-3D-flat
Hi @mmharris,
Check if Fusion 360 is up-to-date.
It should be available by default now up on the 3D milling tab.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
New Version failed to load ... as soon as I rebooted with latest rev of Fusion 360 3D Flat icon appeared.
THANK YOU both.
