How do I delete a single tab that was placed "at points," without deleting all my tabs?
Solved by JetForMe. Go to Solution.
Hold CTRL and click on that point. You can also mouse click and drag to a new location on that line.
When I do that (on macOS), I get this. Okay and cancel just close the tool path dialog:
However, shift-clicking does delete it.
A more Mac-like thing would be to be able to click the tab to select it, then hit delete to delete it. Also, right- or control-clicking it and bringing up a menu with "delete tab" as an option would be good. But at least there's a way.
The tab isn't really a "thing" though, it's just inserted by the toolpath and you get a preview of that when you've got points selected for them.
I do agree that better documentation would have solved this before it was an issue though.
It is most certainly a "thing," even if it's not a feature of the model. As far as "things" to be selected and manipulated in computer user interfaces goes, it's very much a "thing."
Perhaps I was unclear. It is not a model to be selected. It is defined by parameters set forth in the toolpath and given a representation, much as a stock definition is given a representation. While there are ways to interact with this in only one toolpath that I'm aware of (WCS Probe) it isn't a selectable "thing" like other present geometry is.
That's what I meant.
If you want it to be selectable as a "thing" like actual model geometry is, then submitting a new idea here would be the course of action to take: http://forums.autodesk.com/t5/hsm-ideas/idb-p/231
On windows machine -> Push ctrl and then left click on the tab position point.
