I bought some chamfer mills that would be suitable for back chamfering holes, but I am a little fuzzy on how to define the cutter geometry and of the 2D strategy.
Solved by a.laasW8M6T. Go to Solution.
Alright, I managed to get a decent profile of the cutter geometry. I should remember that I eventually prevail in these matters. Perhaps someone might chime in with some CAM approach please.
I'm guessing you made a form tool?
here's and example using 2d contour and stock to leave to get a chamfer top and bottom
if you want a more advanced way of doing it there this article which uses expressions
https://cadpro.io/knowledge-hub/undercutting-backside-chamfers-in-autodesk-fusion/
I will check out the link you so graciously offered. Lets call it solved.
thanks
