Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Cutoff path not following geometry
3 REPLIES 3
flatout3d
349 Views, 3 Replies
In this example I have a grooving tool defined to blend a radius and then cutoff down the back face. The tool seems not to want to plunge down no what I have tried. I show 2 tool sequences that I tried at the end of the program, each one is the same only the tool tangent point is defined at opposite edges of the square cutoff insert in each case since i thought that this may get it to work however both of them show a similar result. Hope someone can help.
3 REPLIES 3
akash.kamoolkar
in reply to: flatout3d
@flatout3d This is a known issue with using sketch geometry. The only workaround for now is to add this blend to the model and have the toolpath work off the model.
Akash Kamoolkar
Software Development Manager
flatout3d
Thanks I will try, if possible please attach my post to the bug fix for that issue
akash.kamoolkar
@flatout3d this was fixed in the Fusion update that recently went out.
Akash Kamoolkar
