In this example I have a grooving tool defined to blend a radius and then cutoff down the back face. The tool seems not to want to plunge down no what I have tried. I show 2 tool sequences that I tried at the end of the program, each one is the same only the tool tangent point is defined at opposite edges of the square cutoff insert in each case since i thought that this may get it to work however both of them show a similar result. Hope someone can help.
Solved by akash.kamoolkar. Go to Solution.
@flatout3d This is a known issue with using sketch geometry. The only workaround for now is to add this blend to the model and have the toolpath work off the model.
@flatout3d this was fixed in the Fusion update that recently went out.
