I am a hobby user and just exploring the manufacturing capabilities of F360. Could use a little help determining what toolpath would be most appropriate for the attached object's interior domed hex shape. I have already been able to
create toolpaths for the outer rabbit and the inner top ring and hex pockets. I am however having difficulty selecting the interior dome hex sides for roughing and finishing.
This a small die (1.5 in outer dia and hex of 0.5 in) and I will be using a .125 FEM to rough and a .0625 TBN to finish. What say you?
TIA
RT
Solved by ChristopherMarion. Go to Solution.
You are going to want to use a 3d Finishing strategy. I suggest starting with a Scallop first, since it will machine both the vertical and horizontal regions in one go. If you have access to Steep & Shallow, that would be my first choice.
Both Radial and Spiral may give you nice results as well.
Upload the file if you need a closer look.
Thanks for the heads up. I was able to use a combination of pocket and scallop. Only broke one tool!
RT
Good to know. Hopefully you get versed enough down the road to not break any tools 😁
