Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Correct Toolpath for this object
3 REPLIES 3
ralph.tuttle
177 Views, 3 Replies
I am a hobby user and just exploring the manufacturing capabilities of F360.  Could use a little help determining what toolpath would be most appropriate for the attached object's interior domed hex shape.  I have already been able to
create toolpaths for the outer rabbit and the inner top ring and hex pockets.  I am however having difficulty selecting the interior dome hex sides for roughing and finishing.
This a small die (1.5 in outer dia and hex of 0.5 in) and I will be using a .125 FEM to rough and a .0625 TBN to finish.  What say you?
TIA
RT
3 REPLIES 3
Hi @ralph.tuttle
You are going to want to use a 3d Finishing strategy. I suggest starting with a Scallop first, since it will machine both the vertical and horizontal regions in one go.  If you have access to Steep & Shallow, that would be my first choice.
Both Radial and Spiral may give you nice results as well.
Upload the file if you need a closer look.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
ralph.tuttle
in reply to: ralph.tuttle
Thanks for the heads up.  I was able to use a combination of pocket and scallop.  Only broke one tool!
RT
Hi @ralph.tuttle
Good to know.  Hopefully you get versed enough down the road to not break any tools 😁
Christopher Marion
SolidCAD - Canada
