Fusion Manufacture
Comment inside a "writeBlock" Postprocessor
4 REPLIES 4
lufti2XPD8
1047 Views, 4 Replies
Hey there,
just wanted to ask if its possible to add an comment inside a "writeBlock" so the comment will appear in the same line instead of a new line
Instead of:
N85 G55
N90 G0 A0.
N95 (ROTATE A-AXIS)
I want it to be
N85 G55
N90 G0 A0. (ROTATE A-AXIS)
Thanks in advance!
4 REPLIES 4
Arun.rs
in reply to: lufti2XPD8
Hi @lufti2XPD8
Thanks for raising your concern via Forum.
You can use '+' operator to add any line inside "writeBlock" function and this will appear in the same line.
Hope this helps.
Regards
Arun.RS
Technical Consultant - Post Processor
lufti2XPD8
in reply to: Arun.rs
Awesome thx a lot!
lufti2XPD8
Sorry to annoy you again but it i got trouble now to add my tool description to same line where my tool call is.
    writeToolBlock(
      "T" + toolFormat.format(tool.number),
      mFormat.format(6)
    if (tool.description) {
      writeComment(tool.description);
is the code i am using right now
Arun.rs
Hi @lufti2XPD8
Apologies for delay in reply.
You can have tool number and tool description in same line by giving below comments.
 writeBlock("T" + toolFormat.format(tool.number), mFormat.format(6), tool.description ?  formatComment(tool.description) : "");
Hope this helps!
Regards
Arun.RS
Technology Administrators
