Hey there,
just wanted to ask if its possible to add an comment inside a "writeBlock" so the comment will appear in the same line instead of a new line
Instead of:
N85 G55
N85 G55
Solved by Arun.rs. Go to Solution.
Hi @lufti2XPD8
Thanks for raising your concern via Forum.
You can use '+' operator to add any line inside "writeBlock" function and this will appear in the same line.
Hope this helps.
Regards
Sorry to annoy you again but it i got trouble now to add my tool description to same line where my tool call is.
Hi @lufti2XPD8
Apologies for delay in reply.
You can have tool number and tool description in same line by giving below comments.
writeBlock("T" + toolFormat.format(tool.number), mFormat.format(6), tool.description ? formatComment(tool.description) : "");
Hope this helps!
Regards
