Would be nice to have the ability to overwrite the cloud templates when doing a store template. Sometimes I my load a template and want to store it with some changes.
The last time I tried if you use the same name you get a dialog asking if it's OK to overwrite.
Mark
Edit just tested it and it does still work.
Mark Hughes
Owner, Hughes Tooling
Yep, sometimes it is a pain to have to remember exactly what the template name is including spaces and such. Since there is not real way to sort or organize templates I resort to using lenghty names. Just thinking there may be a better method.
Yes I know what you mean. What you can do is from the menu click Select Template and file manager will open and you can grab the name from there.
Mark
Mark Hughes
I will have to look into it, because on mine when you hit select template it takes me to the local folder, my clould templates don't appear in the local folder on mine.
I hadn't noticed that, it seems like it should take you to the cloud folder if you have cloud libraries enabled. Also would be nice to have a proper save dialog so you can see what templates you have when you create a new one.
Mark
Mark Hughes
Since cloud templates are in A360 it would be cool if they showed up in the data manager and you could just drag them on the cam browser to create them.
