Solved by schneik-adsk. Go to Solution.
More info: This appears to be an issue with a specific tool. I have a 1/8 90 degree spot drill as tool 2. I am unable to change it to tool 10 for example. I can change all other tools. In windows I can successfully change all tools. I shared this file: http://a360.co/1INteYl
Hi Paul,
Thanks for letting us know the issue. We will take a look later. For a workaround, can you please try to create a new tool library folder and then drag the spot drill tool into it and then edit the tool number? Any more questions please let us know. Thanks.
