Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Change Tool Number
4 REPLIES 4
1526 Views, 4 Replies
Change Tool Number
How do change the tool number of a tool in my Document library? I can edit it in the library manager, but when I save the tool I get a message that "Tool data changes cannot be undone". I'm ok with that, but when I click ok my changes are discarded.
How do I change the tool number of a tool in my program?
I had the same problem before the update but expected this was a bug that would be fixed in Jan update.
4 REPLIES 4
More info: This appears to be an issue with a specific tool. I have a 1/8 90 degree spot drill as tool 2. I am unable to change it to tool 10 for example. I can change all other tools. In windows I can successfully change all tools. I shared this file: http://a360.co/1INteYl
schneik-adsk
Thanks for the added information. I'll bring your post up with the team and get some ideas on what is going on.
Kevin Schneider
adsloud
Hi Paul,
Thanks for letting us know the issue. We will take a look later. For a workaround, can you please try to create a new tool library folder and then drag the spot drill tool into it and then edit the tool number? Any more questions please let us know. Thanks.
Debbie Lou
Sr. QA Engineer for HSM CAM
Haven't had an opportunity to mess with this because I've been trying to get work done. But, it doesn't take much playing around to see tool re numbering flakiness. Also, when setting speeds and feeds within an operation, the chipload calculators don't work.
Any plans to straighten this out before next major update?
I thought tool manager was supposed to be the same in windows and Mac after the Jan update. What happened to that?
