Hi everybody!
I have a question about chamfering with facemill/bullnose mill.
Im using a parallel function to make this work.
Its chamfering actually fine but i have to make longer exits from detail, becouse mill goes down in the detail when milling chamfer.
How to make this happen? I tried all the options and I can't find the solution.
Besides, I have already tried a Contour function where i aslo can't find the solution.
Is that even possible? Maybe Im using wrong fusion360 function?
Thanks for help!
(I need to simulate look like in the screenshoot)
"Longer exits from detail", I assume this is a language translation wording? If you are referring to needing to increase the distance, then Patch Surfaces (in Design space) are going to be your friend in CAM programming. Offset the surface a zero amount, and then Extend the edges to get your tool well off the part
