Fusion Manufacture
chamfer strategy for a slot on a tapered turn
2 REPLIES 2
mike_miller515
216 Views, 2 Replies
Can anyone coach me on the proper way to machine the chamfer this key slot on a tapered turn? I've been able to create a trace to "sort of" chamfer it. We have serveral parts with this same feature but this process was rather tedious and i am wondering if there is an easier way.
when i select the contour i get this where it pulls the geometry in a straight line instead of the angle.
2 REPLIES 2
Marco.Takx
in reply to: mike_miller515
Hi @mike_miller515,
The Trace operation is exactly what you need to make a chamfer when the edge is tapered along the Z-axis.
I made 2 scenarios so you can choose which one is best for you.
The 2D Chamfer or 2D Contour operation can only be used on flat areas.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
mike_miller515
in reply to: Marco.Takx
Sorry for the late reply, but thank you Marko this was exactly what i needed!
