Can anyone coach me on the proper way to machine the chamfer this key slot on a tapered turn? I've been able to create a trace to "sort of" chamfer it. We have serveral parts with this same feature but this process was rather tedious and i am wondering if there is an easier way.
when i select the contour i get this where it pulls the geometry in a straight line instead of the angle.
Solved by Marco.Takx. Go to Solution.
Hi @mike_miller515,
The Trace operation is exactly what you need to make a chamfer when the edge is tapered along the Z-axis.
I made 2 scenarios so you can choose which one is best for you.
The 2D Chamfer or 2D Contour operation can only be used on flat areas.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Sorry for the late reply, but thank you Marko this was exactly what i needed!
