Fusion Manufacture
Chamfer endmill simulating incorrectly
2 REPLIES 2
hatch789
243 Views, 2 Replies
Hi guys, I have a really simplified version of a much more complex part I'm making here as an example for you. This real part has a lot of carefully chamfered holes that I'm trying to ensure things are going exactly as they should before I cut material.
Why on earth is this chamfer mill acting so odd in simulation? It's showing collision and it's simulating a bunch of extra material being milled out than it should. The part cuts perfectly on the machine but often I use simulation to dial a process in and then run it on the machine. Here however the simulation is way off for me.
https://a360.co/3Usasme
2 REPLIES 2
seth.madore
in reply to: hatch789
Turn this Optional Feature to "ON"
Result:
Seth Madore
hatch789
Thanks that was the magic ticket. I was like WTF is going on here???
