Hi guys, I have a really simplified version of a much more complex part I'm making here as an example for you. This real part has a lot of carefully chamfered holes that I'm trying to ensure things are going exactly as they should before I cut material.
Why on earth is this chamfer mill acting so odd in simulation? It's showing collision and it's simulating a bunch of extra material being milled out than it should. The part cuts perfectly on the machine but often I use simulation to dial a process in and then run it on the machine. Here however the simulation is way off for me.
Solved by seth.madore. Go to Solution.
Turn this Optional Feature to "ON"
Result:
