Fusion Manufacture
Can't machine a round slot with compound curve edges
5 REPLIES 5
jasonmtbx
225 Views, 5 Replies
I can't seem to figure out how to machine this round slot with a ball end mill that is the same diameter. I tried creating a line in the middle so I could trace it with tip comp off, but since the edges are compound curves, it won't let me pick up the mid point.
Any help is much appreciated, thanks.
5 REPLIES 5
seth.madore
in reply to: jasonmtbx
Help is going to be limited without the file. Can you share it?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
jasonmtbx
in reply to: seth.madore
Of course, here you go:
daniel_lyall
See if this helps, example attached.
 </p
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
seth.madore
in reply to: daniel_lyall
Thanks @daniel_lyall , you replied while I was waiting for my ScreenCast to upload. Not to let a good Cast go to waste, here's another slightly different method to accomplish basically the same thing:
Seth Madore
jasonmtbx
Perfect, thank you both!
