I can't seem to figure out how to machine this round slot with a ball end mill that is the same diameter. I tried creating a line in the middle so I could trace it with tip comp off, but since the edges are compound curves, it won't let me pick up the mid point.
Any help is much appreciated, thanks.
Solved by seth.madore. Go to Solution.
Solved by daniel_lyall. Go to Solution.
Help is going to be limited without the file. Can you share it?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
See if this helps, example attached.
</p
Thanks @daniel_lyall , you replied while I was waiting for my ScreenCast to upload. Not to let a good Cast go to waste, here's another slightly different method to accomplish basically the same thing:
