Hello Again, I'm getting a message "No toolpath generated" when I try to create a facing operation. The piece of stock that I'm trying to face was saved from a previous Setup that machined the top side of the stock and inserted as a mesh body. I've done this same thing for another model I created and had no problem but can't seem to get it to work this time. Maybe I'm just having a brain fart but would appreciate someone having a second look. File is attached.
Thanks.
Thanks.
Solved by LibertyMachine. Go to Solution.
Click on the Setup > Stock, and you will see that it says "1 Missing, 1 Mesh"
Clear the selections and reselect the mesh body
Thanks kindly Seth. I knew I was having a brain fart.
Cheers!
Cheers!
