Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Can't generate a facing toolpath
2 REPLIES 2
oldtbone55
319 Views, 2 Replies
oldtbone55
@daniel_lyall
Hello Again, I'm getting a message "No toolpath generated" when I try to create a facing operation. The piece of stock that I'm trying to face was saved from a previous Setup that machined the top side of the stock and inserted as a mesh body. I've done this same thing for another model I created and had no problem but can't seem to get it to work this time. Maybe I'm just having a brain fart but would appreciate someone having a second look. File is attached.
Thanks.
@daniel_lyall
Thanks.
2 REPLIES 2
LibertyMachine
in reply to: oldtbone55
LibertyMachine
Click on the Setup > Stock, and you will see that it says "1 Missing, 1 Mesh"
Clear the selections and reselect the mesh body
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Seth Madore
oldtbone55
in reply to: LibertyMachine
oldtbone55
Thanks kindly Seth. I knew I was having a brain fart.
Cheers!
Cheers!
