How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
hello everyone.
I am using fusion 360 for quiet a long time but from few days I can't able to open my fusion 360 application.
it first says to sign in and when I click on that it says some like"check your browser to sign in" but i didn't have anything in my browser.
@vtu11882 Can you check a couple of things?
1. What is your default browser that you use? If you switch to another browser does it automatically launch the browser?
2. When you are launching Fusion 360 can you click on Ctrl+Shift to launch the Fusion service utility. In there can you please run the Gather system info and attach the zip files that it generates to this post, please?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
I am having the same exact issue and can't seem to find a solution online. Please see attached "System Info". Cheers
@goodman.zak Thank you for the log files. Checking with the team here on what could be happening.
Did you try changing the default browser and see if that help?
Autodesk Fusion
Join Fusion Insider
Hi @goodman.zak ,
Would you please check whether it is caused by permission limitation to tmp folder on Mac oS? /private/tmp
folder need permission for the current user to create the Autodesk-IDSDK-IPC
as sub-folder, so that if it doesn't have enough permission, the request is blocked. Please try the following things:
1. Correct the permissions of tmp folder with referring to the image below.
2. Or delete /private/tmp/Autodesk-IDSDK-IPC
folder
How to buy
