Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
CAM wont aprove certain items as a group with a cut path?
6 REPLIES 6
zmihlrad
437 Views, 6 Replies
zmihlrad
Wasn't sure how to phrase this but I am using an extruded image in CAM to generate g code for plasma cutting.
I select "Inner loops" and "always inside" and I make my selection. Everything comes up fine, and when I generate the toolpath it kicks back an error and leaves the item in the picture in this case out which I then must manually create an additional toolpath for.
If I turn off all lead-in and lead-out then it resolves it. But I do not see why it is effecting it when the space is more than large enough to fit these features?
The section being left out in the photos is the scale in the center.
Thanks!
Thanks!
6 REPLIES 6
LibertyMachine
in reply to: zmihlrad
LibertyMachine
Can you share your file?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Seth Madore
zmihlrad
in reply to: LibertyMachine
zmihlrad
The SVG is attached.
LibertyMachine
LibertyMachine
Ok, but what about your Fusion file, can you share that?
File > Export > Save to local folder. Return to thread and attach the .f3d file.
Seth Madore
Seth Madore
zmihlrad
zmihlrad
Apologies, new to this.
File is attached.
Thanks.
File is attached.
Thanks.
LibertyMachine
LibertyMachine
I don't have a good answer, sorry. At least you DO have a workaround and are able to get the part cut out, granted, in two operations. I think there is a bug at play, but it may be beyond my paygrade to troubleshoot. I 'll send this up the pipeline and see if I can get it looked at
Seth Madore
Seth Madore
cj.abraham
cj.abraham
Appears to be a toolpath kernel issue. I've created ticket CAM-11948 to investigate.
