Is there a place I can find the additive manufacturing post processor variable list relating the options in the print settings editor to the post processors?
Second questions, if I want to add auto bed leveling is the only option to use the FFF Post Creation Utility? or can I add a checkbox somehow to the print settings window?
Hello @campbellqn
You won't be able to access all the variables defined in the print settings.
But for a list of the available variables passe to the post, you can follow this link to download the processor manual.
In the paragraph 9.3, you will find the objects and variables accessible in the post.
For adding the bed leveling command, depending on your knowledge on javascript programming, you can either use the FFF post creation utility, or you can use VS Code in conjuction with the Autodesk post processor utility useable with VSCode, in order to edit the post processor, written in javascript.
Javascript will allow you to do nearly aanything and use all tha available variable.
The post utility will not give you full access, as it's an easy to use way of editing post.
Have a pleasant day.
Regards
Hello @campbellqn
Regards
