Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
4th Axis Error post pro
5 REPLIES 5
francois_moreau
440 Views, 5 Replies
I use a 3 axis MAchine, wit Richauto Postprocessor.
The machine has a Rotary Axis along Y, (with name " C " axis on the hardware)
because the Richauto postpro you can find on the HSM fusion library is only a 3 axis postpro,
I find the RS-274D Autodesk multi axis
I tried to make a simple toolpath,
and become an Error when I tried to postrocess it
Error: Tool orientation is not supported for available machine axes.
Machine angles not supported: A-121 C-90
could it be link to machine configuration?
or Wehre can I find how to test my machine?
Must I edit the postprocessor?
I find the new training guide pdf about this process, but I do know wat to do with it
https://cam.autodesk.com/posts/posts/guides/Post%20Processor%20Training%20Guide.pdf
thanks
François Moreau
bénévole sur le programme Fusion:
5 REPLIES 5
engineguy
in reply to: francois_moreau
@francois_moreau
Not sure if the following is what you are looking for but here goes anyway. Have a look at the video first and if it`s what you need then have a look at the attached file and modified Fanuc multi axis Post Processor, hope it helps 🙂
francois_moreau
in reply to: engineguy
thanks @engineguy
with the Fanuc rotatif I could edit a .nc gcode
I hope my Machine, Richauto, will understand it, I make a try and let it know if it turn how it must.
François Moreau
do not work. (but move, it is positive)
i made a small test without the 4 axis, with fanuc pp
it is working, look like ok. (I didnot take the time to mill it, but in the air it look it works normaly)
then I try the rotative test we speek about,
and it only move on the Y axis, nothing on the C axis (like it put everything together on the Y (Y+C) )
here small video of the problem
https://youtu.be/uzzNQVQeZDU
on this video I try my file 1003.nc, but I try also your 2009.nc with the same problem.
otherwise with the DSP B-18 Richauto handle,
clockwise is C-
so try I to adapt the Fanuc PP, or make other try with a other one? (witch one?)
good here continue to find the solution or post I the question on the autodesk HSM PP forum?
thanks
François Moreau
engineguy
@francois_moreau
Thank you for the video, I can see that on your controller there is X/Y/Z and A axis, not C Axis, that is possibly why your 4th axis does not turn, I have modified the Post Processor to output A Axis moves instead of C Axis, as far as I know your RichAuto control should accept the Fanuc Inverse Time code so give the new PP a try, hopefully it will work this time 🙂 🙂
francois_moreau
@engineguy
thanks, It's working much better
https://youtube.com/shorts/YjMcQnlA20I?feature=share
still not smooth, it make the first full round (A axis only turn) everything ok
then for the spiral it makes a lot off run stop on both Y and A axis
is it also possible that it run slowly as in the simulation ( about 1 minute in simulation (for the first toolpath and a second minute for the second), but much more needed I thing on the CNC)
François Moreau
